CATIA KEYBOARD SHORTCUTS 6
CAD2015
Computer
Jan 21, 2006
2,054
I've found out (unintentionally) about Catia browsing the open files (CTRL+TAB).
Does anybody know other similar shortcuts?
MZ7DYJ
While hovering over an ambiguous selection clicking the up/down arrows will cycle through the possible entities you may be trying to select.
Aside from that I have setup some hot keys:
Hide/Show: Space Bar
Constraint (in sketch): End key, Also mapped to an extra button on my mouse
Fit All: Home key
Rob Stupplebeen
Ctrl + u will do an Update
ESC twice will interupt most commands
I didn't know about ESC twice command!
Thanks Jackk!
MZ7DYJ
That is detailed list of shortcuts ferdo. Adding to that you can create your on shortcuts also in catia.
customize ---> Commands(tab) --> select the Categories --> Commands --> show properties --> give the required key in accelerator feild --> close.
Sriram
I just learned about ALT + ENTER as a shortcut to Properties, thanks to David Summerscales on COE.org
(it's also on the FAQ list)
My most favorite one is to program ALT + ENTER to one of the extra buttons on my mouse.
While it is not a keystroke combination shortcut, I do like using the Power Input box to quickly find and select things.
For example "n:Rosemount" will find any Rosemount instance in an assembly.
I agree that the Power Input box is handy - my favorite is c: force update to refresh drawings
Great information.......!
Thanks.
MZ7DYJ
MarkAF (Mechanical)
How did you program ALT + ENTER to one of the extra buttons on your mouse?
How should I select the extra button on my mouse for this command?
MZ7DYJ
you can do that in your mouse driver program (maybe not all mouse driver are equal) , not in catia.
Eric N.
