Carbon
bigTomHanks
204
I'm a mechanical engineer but I am currently serving in the U.S. Army. After we come in from a field training exercise our machine guns have a lot of carbon build-up. To help accelerate the process of recovering our weapons I would like to use a hand held wire disc to remove the carbon. The piece of the gun that I would like to use the wire disc on is steel. My question is: What type of wire disc should I use to remove the carbon without damaging the bolt?
When I was in the US Army, we had brass brushes to remove carbon deposits from the internals (like bolts). I would recommend brass, since it is softer than steels, and already has been tested by the US Army.
Cory
I also think a soft metal is preferred.
What does the US Army recommend?
Thought about a SOS pad? If it gets cooked on stuff off the pot, maybe carbon off your weapon?
"Do not worry about your problems with mathematics, I assure you mine are far greater."
Albert Einstein
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
bigTom,
Check with Brush Research. I have used their products and expertise in the past for several different purposes and found them good to work with. Google 'em.
A second option might be to contact someone like Olin who makes a lot of gunpowder. I'm just guessing but they would be likely to have a solvent or method worked out.
Griffy
What weapon are we talking about here? Wouldn't you remove the bolt prior to cleaning?
[green]"Art without engineering is dreaming; Engineering without art is calculating."[/green]
Have you read faq731-376 to make the best use of Eng-Tips Forums?
The weapon that we are cleaning is a 240C machine gun, and yes the bolt is removed for cleaning.
Depending on the degree of hardening of the build-up, I've used an assortment of 3M's ScotchBrite industrial abrasives (plastic scouring fabric) and assorted other knock-offs. They're used in metal finishing industry for everything from rough removal (i.e. in polishing operations) to micro-polishing. Depending on the grade, it can be quite aggressive and may take off the base coating material.
Jim Sykes, P.Eng, GDTP-S
Profile Services
CAD-Documentation-GD&T-Product Development
At my army service, ages ago, in the middle of nowhere, I was using tooth polish paste because it was available,you know...smile, boys...
m777182
I kind of wonder about
oven cleaner, the kind
that you do not have to heat
the oven.
Oven cleaner! Interesting, it might be worth an experiment to see if it works.
What's the matter with CLP (US Army Cleaner Lubricant Protectant) and brass brushes? If you want to reduce manual labor, use a wire wheel brush with a drill.
Cory
bigTomHanks,
Thank you for your service
Joe
I would not go for oven cleaner. Very caustic. Probably would strip the finish and pit the base metal.
