skeletron
- Jan 30, 2019
- 882
CSA O86-19 Clause 5.3.2 discussed the load duration factor (KD). For short-term loading, KD=1.15. The Clause also states "...shall be multiplied by a load-duration factor, KD, in accordance with Table 5.1 but not exceeding 1.15..."
The Canadian Wood Council's "Engineering Guide for Wood Frame Construction (2014 Edition)" Clause 3.4.2 also provides insight into the load duration factor (KD). This clause states "...the specified strengths and resistances may be multiplied by a load duration factor KD=1.25 for wind and earthquake design..." This document provides tabular solutions and capacities for common residential, light-frame situations. Reviewing some of these numbers indicates that the KD=1.25 factor has been applied.
One of the key clauses of Part 9 (CL 9.4.1.1) indicates that along with conforming to Part 9 requirements, the design shall be in accordance with "...good engineering practice such as provided in [CWC's guide]..."
What is everyone's interpretation of this?
(a) Does this mean you can apply KD=1.25 (as per CWC's guide) throughout the Part 9 structure (nail connections, shearwall capacities, etc.)?
(b) Or does this mean you apply KD=1.15 (as per CSA O86) throughout, unless using solutions straight out of the tables or interpolated from the tables?
The situation is primarily for force transfer elements under seismic loading (e.g. framing connections like nails from bottom plate to rimboard, framing clips to connect between vertical LFRS, etc.) and trying to attain the +20% factor as per CSA O86-19 CL. 11.8.6. I've always applied (b) and rarely dip into the tables because they are metric. The benefit of using KD=1.15 is that that is the standard short-term factor applied in manufacturer's tables as well (ie. Simpson or Mitek). But, allowing myself to get into the weeds and check certain calculations, I noticed that this increased KD value is being applied and that it could be beneficial to utilize this so that I can maintain common spacings (32", 24", 16", 12", etc.) rather than always having to bump up. I think this is a nitpicky curiosity thing on my end, but I'd be curious to know how others approach this or if they even think about it at all.
