Can anyone tell me where I'm going wrong
Alan Lowbands
Aerospace
May 17, 2017
274
Hi All,
I'm trying to fill some items on drawings using macro's with pop up boxes.
I've got most of it to work but it's in sheet background.
When I try to get it to alter some text on the working views I get an error 'Set DrwText = DrwTexts.GetItem("Text.222") 'TEXT NUMBER'
I am a bit stumped on how to work on the 'working views'
any help (as always) would be appreciated
code below.
Sub CATMain()
CATIA.ActiveDocument.Selection.clear
Set drawingDocument1 = CATIA.ActiveDocument
Set selection1 = drawingDocument1.Selection
Dim DrwDocument As Document
Dim drwsheets As DrawingSheets
Dim drwsheet As DrawingSheet
Dim drwviews As DrawingViews
Dim drwview As DrawingView
Dim DrwTexts As DrawingTexts
Dim DrwText as DrawingText
Set DrwDocument = CATIA.ActiveDocument
Set drwsheets = DrwDocument.Sheets
set drwsheet = drwsheets.item(1)
set drwviews = drwsheets.item(1).views
set drwview = drwviews.item(2)
Set DrwTexts = drwview.Texts
Dim oPART
oPART=InputBox ( "Enter Part number" ) 'pop up box
'oPART="XX/XXX/XX" 'for batch
Set DrwText = DrwTexts.GetItem("Text.221") 'SHEET No (this is on sheet background
DrwText.text = oPART
Set DrwText = DrwTexts.GetItem("Text.222") 'TEXT NUMBER (this is on the working views
Document-> sheets-> views-> texts
set myTxtsView0 = drwsheet.views.Item(0).DrawingTexts
set myTxtsView1 = drwsheet.views.Item(1).DrawingTexts
like this you will be able to grab texts from view0 or view1
To get active view from active sheet texts:
set myActiveTxts = CATIA.ActiveDocument.Sheets.ActiveSheet.Views.ActiveView.DrawingTexts (or something like this)
Eric N.
Thanks itsmyjob
Could I ask would that go in the code please ?
Trying to get my head around how the call up for the drawing is layered.
ie. what each line is actually doing.
what are you trying to do?
yes the few lines I presented could be used in your code... with some correction i guess...
I am just trying to show you the way you can get drawingtext collection from views, you do what you want with it.
Please find the v5automation.chm file on your installation path and get familiar with CATIA APIs.
Eric N.
Found the v5automation.chm and found a copy of 'VB Scripting for CATIA V5 4th Edition' that I got years ago.
Hopefully I'll get my head around some of this eventually.
Thought id try something simplpe like renaming the Text.object numbers.
Thats not goiung well either.
Hats off to anyone who has a grasp of this stuff lol
the Name of the text is the name the object text does have. the Text is the the value of the text you see on the drawing.
you might have
set myTxt = drawingtexts.item(3)
and myTxt.Name = "text.3" (the name of the text object) and also myTxt.Text="Hello world" (what you see on the drawing)
so changing values:
changing the value of the text in the drawing? you can do so with myTxt.Text = "Goodbye cruel world..."
changing the object name? you can do this myTxt.Name ="Text.007"
Eric N.
Thanks itsmyjob,
Why can't they expliane it like that in the books :)
really appreciated
regards
Alan
