jnichol
- Oct 23, 2001
- 11
I'm hoping someone out there wiser than myself can help me finally put this question to rest.
I work for a mid-sized structural firm doing work across the country. Often times the buildings we design have steel roof decks, and (3) long shearwalls along the perimeter. One side will have no lateral support what so ever. This can be because one side of the building is constructed entirely of storefront glass, or it may be because there is an expansion joint in the middle of the deck.
My understanding is that flexible diaphragms distribute forces base on tributary area (an are unable to transmit torsion forces), rigid diaphragm on the other hand transmit forces based upon rigidities (and can take torsion). Semi-rigid fall in between these two extremes.
When a building is 'U' shaped, and wind/seismic forces are going in the direction parallel to the lone wall, can a flexible diaphragm even stand up? Because the center of rigidity and the center of force are at different locations, torsion is required for stability, but a flexible diaphragm can not transmit such force (or can it). Does that mean that my diaphragm always has to have (4) sides if it is flexible?
Then, should I treat this condition as semi-rigid or rigid? Best I can tell SEOC say do both (semi-rigid). Great concept, but if there needs to be (4) sides for a flexible diaphragm to work since it can not transfer torsion, and I dont have it, what should be done?
Also, if a flexible diaphragm can indeed take torsion than what would be the difference between a flexible and rigid analysis for loading in this direction?
Reason for the question, we have just completed two CA jobs in the last 3 months. One code reviewer says prove the diaphragm is rigid, the other says prove its flexible. Cant win for loosing!
Thanks in advance for all your comments on this condition!
