am
- Aug 30, 2001
- 60
I am looking for some analysis tool to calculate the exact [as close as possible] length of guy wires for a very tall guyed mast. I believe guy attachment location on the mast will at about 250m, anchor radius will be about 180m. I anticipate guy wire diameter will be in the range of 75mm or more. The guy will have high initial tension once installed. The straight length is 308m with above parameters, but there will be significant sagging in the wire. The majority of sagging will occur towards the upper half of the guy wire. I have to calculate the length considering the sagged length under specified initial tension.
It will be of great help if any of you can give me some guidance in this regard.
AM
AM
