PwrCntEE
- Dec 27, 2002
- 15
I'm trying to reflect a fault level through a single phase transformer winding. I know I can use the %Z and the rated current to get the maximum unlimited secondary fault current. But If I know the actual level on the primary, how do I relect it thru to the secondary? I cannot just use the turns ratio cause I'm looking at current....or can I?
Data:
12,470V pri, 240/120V (center-tap), 15Kva, 1.3%Z
Available on the 3ph line (steady state)
bolt=1653A, L-L=1494A, L-N=2107A, X/R=2.1
Data:
