machineryguy
- Dec 20, 2002
- 6
Hello all,
I was hoping to get some feedback/advice from the group.
I have a frame for which I would like to get a much better handle on what is going on with it.
I have 3-axis acceleration data at 5 locations on a frame with respect to time (about 60 seconds worth). What I am trying to calculate is how to represent the frames motion over time given the acceleration data. For now, I am going to keep it simpler, by assuming planar motion (setting aside the z accelerations for now). (let X be parallel to ground, and Y vertical, with Z perpendicular to long axis of frame)
I pulled out my old dynamics text, and I THINK that I am going to need at least 3 of the accelerometers data to be able to obtain the general,planar motion of my "rigid" body.
I'm looking at a chapter labeled "Relative-Motion Analysis:Acceleration"
To state the acceleration of a point on a rigid body, you relate it to another points acceleration and the relative acceleration of the two. I will need to know alpha (angular acceleration of the rigid body), and omega (angular velocity of the rigid body). Obviously, I know the relative position vectors, as I know where the accelerometers were put.
A1 = ACG +A1/ACG = ACG + (alpha X r1/CG) - (omega^2*r1/CG)
A5 = ACG +A5/ACG = ACG + (alpha X r5/CG) - (omega^2*r5/CG)
A3 = ACG +A5/ACG = ACG + (alpha X r3/CG) - (omega^2*r3/CG)
here,
A1, A3, A5 = accelerations at point 1, 3, and 5.
ACG = acceleration at the frames center of gravity.
alpha = frames angular acceleration
omega = frames angular velocity
r1/CG, etc = position vector from point 1 to center gravity
Does this look correct to everyone? I appreciate your thoughts, Thanks!
here,
