Calculating air velocity due to pressure in a tank
pwilkins
I have a tank of dry, compressed air at 72F and 200 psi and a 1/4" ID hose as the outlet (L=25 ft, but I am not worried about friction loss right now). Maybe I am just missing a really simple calculation, but I am having trouble calculating the velocity at the end of that hose. Can someone help me out?
Figure out what your nozzle shape is, and have a look at a compressible flow table?
You'll be choked at the outlet, the velocity will be the speed of sound in air.
Depending on which flow equation you use, it'll be between 250 and 350 mph.
Thank you all for your responses. Which flow equation is the appropriate one?
Since the tank is of finite volume, the velocity a the pipe exit will be changing with time.
Not as long as the pressure ratio is above critical and the flow is sonic.
The outlet pressure may be sonic, but as long as the source changes pressure and temperature, the velocity will change.
First of all "sonic" refers to a velocity, not a pressure. When you have a pressure ratio (in air) above 1.893 the flow will be sonic and the velocity through the orifice will be constant. The mass flow rate will be a function of the upstream density but the velocity will not.
Sonic refers to Mach Number =1. It is the ratio of a velocity to the sound speed. For the simple case of isentropic flow from a finite tank, the tank temperature will drop. In that case, with choked flow the sound velocity will drop. Therefore at Mach 1, the choked velocity will drop.
