azrom
Marine/Ocean
- Mar 12, 2003
- 5
I have this winch-reel (540mm wide, Diameter=800mm, cylinderer wall thickness=10mm) that is to be pulled by a wire. The maximum braking load on the winch is 4.3 metric tonnes (42kN).
My task is to check the reel against buckling. I can determine the buckling if I know the relevant pressure on the reel/cylinder wall.
How can I determine the design pressure on the reel if only the braking load is known?
