Calcium Hypochlorite
wwtp2014
Industrial
Dec 12, 2014
50
Dears
I have to choose between two products of calcium hypochlorite ( HTH Easiflo Granules and HTH Shockfrom) from Accepta company to Sterilization permeate water from reverse osmosis which use for Dairy Processing. please for your recommendation and advice
Thank you
Depends on what type of feed system that you plan to use.
With the Shock which is a finer grade material, you probably need a day tank with mixer. If the material sits around for a long time, it will go stale.
HTH has a feeder for the Easiflow briquettes so there is probably less waste and simpler to use.
Dear Bimr
please what do you mean by feed system?
Thank you
actually i have already day tank, mixer, metering pump. so can i use both of them and what is the advantage and disadvantage for both of them
Thank you
The Shock has 10% more chlorine and dissolves quicker. That is the best option for the money.
Do you mean i can use HTH Easiflo Granules with make up tank equipped with mixer and conical bottom, dosing tank with metering pump.so no need for feeder.
and for economic option HTH Easiflo Granules cheaper than Shock type for Kg
Kindly, Is this food grade and can i use it for Dairy Processing or not?
Can you please recommend food grade calcium hypochlorite to be use for Dairy Processing
Thank you
