rockman7892
- Apr 7, 2008
- 1,176
Is there a particular requirement or standard for the sequencing of bus phases in MV Switchgear to be A, B, C, top-to-bottom / left-to-right?
We have an issue where we are installing busduct from a transformer located across from switchgear that has phasing A, B, C left to right on bushings so if we being that directly across to switchgear the phasing in switchgear would be C, B, A, left to right. We are trying to decide if it is necessary to have bus transpose in order to make switchgear phasing A, B, C left to right.
This is single ended gear so that only thing I can see that this would affect would be internal labeling of CT', PT's, etc.. and use in troubleshooting or perhaps a specific standard that requires the A,B,C left to right orientation?
