Broms Method 1
Thawkes
7
I would like to create a spreadsheet to determine the lateral capacity of a single embedded pile using the Broms method. This method involves several charts. You lookup one unitless parameter on the X-axis to determine another unitless parameter on the Y-axis. I've made an attempt to back-calculate the equations of the lines on these charts, but haven't succeeded. Does anyone have any information that will help me find these equations? I've attached a couple of pages from a PDF including two of the charts I'm having trouble with.
Thanks in advance.
 http://files.engineering.com/getfile.aspx?folder=9037f60e-d41f-4a63-8f5a-302727fe53db&file=Broms_Method_from_Reese_Book.pdf
Try this: [link file:///C:/Users/multimedia/Downloads/Broms_Method_from_Reese_Book%20(1).pdf]Link[/url]
The Florida Department of Transportation also has an excellent, freely available MathCAD sheet on drilled shafts that I've used for this: Link. If you have the ability to view it, it might jump start your efforts to parse out the underlying equations.
What a fantastic document cruezer. Thank you so much for posting it!
