3DDave
Aerospace
- May 23, 2013
- 11,257
So, here's the question - just watched what I've experienced - the difficulty of removing pads or a drum due to the rust and uneven wear of the drum/rotor because the pads are inset from the edge of them.
So - I understand the force on the pad or shoe needs to be centered on the width of the pad but why cannot the pad/shoe extend off the edge of the rotor/drum? That way it can wear evenly and remove the rust ridge and everyone is happy? Plus, on pads it should/could leave a sliver of the original thickness so that a glance will give the owner a better idea of how much life he has used and how much is left.
Has this been tried? I don't mean recenter the pistons on the pad so it's off the edge, I mean just make the pad a bit wider so it goes off the edge a little bit.
The example is on an Escalade where they did not include any access to the parking brake adjuster and the rotor was destroyed trying to get by that ridge. Seems like on a parking brake even with some clearance that it would keep the edge of the drum smooth just like the rest where the brake normally contacts.
