Block Explode - Autocad Mechanical 2012
21Pom
131
Hi All,
When I save a file from Inventor 2012 to an Autocad file it works just fine. I then go to open it, again it works just fine, however the file opens up as a block. Again there's nothing wrong with that.
Now when I go to use the Explode button nothing appears to happen. On checking the drawing, the explode command has in fact exploded the drawing, but it has also made two copies of the original block on top of the now exploded drawings whixh need to be erased before I can work on the drawing. Is this normal?
Rgds
Dave R
No, doesn't seem normal to me. My boss is just getting us started on the path to integrating Inventor with our current AutoCAD operations. The only method I've found so far that seems to work (for me) is to "Export" to SAT, and import THAT into AutoCAD, where it comes in as discrete AutoCAD valid solids , and from there I proceed normally in AutoCAD. We use this workflow to do quick layups (3D) for what-ifs, that we haven't discovered a good workflow process for, in Inventor yet. I'm sure there IS one, I just havent't found it yet.
But - this approach has worked reliably for me, so far.
NOW - I'm aware that there's a way to do it "Right" in Inventor - output to a native AutoCAD 3D Solid model. What's that inventor command ?
Thanks -
Charley.
Do a refedit of the block and see how many blocks are within the block that you want to explode.
