PEW
New member
- May 29, 2003
- 140
I've just stripped out the big-end shells from my 1986 made (but remanufactured in '99), tuned 850 cc trials car engine, to investigate a rattle which suddenly occcurred and rapidly got worse. No. 4 conrod had quite a lot of play in the bearing, the other three less so.
The bearing faces of the shells are lead/indium or aluminium (not sure as I didn't build it). All of the shells in the conrod halves are badly pitted on the bearing faces, as if the metal is corroded, but the actual sliding face is polished and there is no sign of smearing. The bearing cap side shells are not so bad but they are slightly dark and discolored.
The crank journals are unmarked, almost perfect. I can discern no play in the main bearings. The engine has done 24,000 miles over seven years.
I've recently changed oil type, from a semi-synth 15W/40 to a mineral 20W/50. This was advertised for "older, classic" engines with wider manufacturing tolerances than modern engines and it gave improved oil pressure as advertised. This oil has done only about 2,000 miles but now smells slightly burnt.
Although I won't be using this type of oil ever again, I'm not sure if the oil is completely to blame; it might be a coincidence. Over the winter of 2007/8 the engine stood for about three months with, unknown to me, a cracked cylinder head around an inlet valve guide, resulting in coolant leakage into one cylinder and about half a pint went into the sump oil. As part of the fix, I used a flushing oil and carried out two oil and filter changes before putting the car back into service.
Question is this:
Just how corrosive is water / glycol coolant in these circumstances, i.e. mixed with engine oil?
Did bearing material corrosion induce a latent problem or was it just more likely to be poor oil quality?
Question is this:
