faromic80
- Feb 14, 2008
- 80
I have a question regarding a simply supported beam overhanging one support. There is a vertical load and load in the plane of the page at the end of the beam. The support nearest the overhang is actually a brace. See the figure I attached. My question is regarding the modelling of the supports for this frame. The brace and beam will be connected to an existing concrete wall with expansion anchors via baseplates. I ran the model using both pin supports and fixed supports. In the case that the supports are pinned, the tension load increases from the fixed case. I'm thinking this is because of the moment basically being converted to an additional tension load on the supports. Another thing I've been debating with myself is how the baseplates will actually behave? I know it may depend on the stiffness relative to loads but in general I think it's safe to design as pinned. What does everyone think?
