gguliye
Industrial
- Apr 17, 2019
- 117
Dear All,
The Crosby has incorporated the balancing piston to its valves and it functions as the secondary bellow. When the bellows ruptures, the unbalanced area of disk holder will expose to the back pressure and this back pressure in turn will affect the set pressure of the PRVs. So, the Crosby has installed the balancing piston to take the force coming from back pressure to itself (the direction of the force will be upward), so the set pressure will not be affected(the force applied on unbalanced area of disk holder will be equal to the force applied to the piston in the upward direction). My question is as following:
can we use the balancing piston alone without any bellows to avoid from the effects of the back pressure completely?
