CSCPE24
- Feb 3, 2008
- 25
Hi All,
I'm even embarassed to have to ask this. But can someone remind me of how I can calculate the reactions at the 4 corners of the rectangle if the CG of the part is offset as shown? The weight of the part is 10 lbs. If the CG is at the center, then we know the reactions should be 10/4 = 2.5 lbs at each corner. But since it's offset, I'm kinda stumped.
I know I have to sum up values in x and y direction from the original CG but I just can't seem to remember everything.
Thanks for all the help in advance!
