LaunchD
- Mar 5, 2005
- 7
Has anyone seen similar experiences or have any ideas to the situation below?...
On a fleet of 2006 GMC trucks (modified into shuttle coaches), we have experienced a problem with battery isolators and auxiliary batteries that "blow up".
The stock GM truck has two main batteries and two 105A alternators. The modified bus has the addition of an auxiliary battery and a 200A isolator. The aux battery is used for some systems that need to run while the bus is turned off. It prevents the need for jump-starts because of drained main batteries. Both gel-cell and deep cycle batteries have been tried (and failed) as the aux battery.
At one point or another, there have been occassions where the aux battery has boiled over and the isolator has blown (diode is shorted out on the main battery side). Data loggers have been installed to monitor the condition of the aux battery.
On most tests, the electrical system appeared normal. However, on one bus, we were able to record and observe that voltages up to 20V were measured across the terminals of the aux battery for a period of about 20minutes. Shortly after, the battery was replaced. Refer to the attachment for voltage readings. The graph does not show the entire period that was logged, only the time immediately before the event.
In the few days before the high voltage spikes and the battery boiled, the data logger showed that the charging voltage on the battery was about 13.5V (it's usually about 14V normally). After the battery and isolator were replaced, the voltage returned to a more stable reading. The graph looks a lot more stable, at least.
What could cause this? Can an automotive alternator output 20V? I am considering the voltage regulators as suspect. We will try to reproduce the events to see what conditions could cause this. But for the meantime, I am really stumped.
Any help/ideas would be appreciated. You may have more questions for me... fire away. Other facts: the main batteries are never damaged. Main electrical systems like headlights, ECU, etc are not damaged (fault codes from the diagnostics port were not found, though, the ECU history is cleared after 40 ignition cycles with no events - which can happen within 2 days). The aux battery and isolator are mounted in their own compartment away from heat. Temperature loggers have never recorded high temperatures (but have only been installed on buses that have not had batteries boil yet).
Thanks,
Dave
Thanks,
Dave
