Assist Gas for Flares
process440
Chemical
Sep 28, 2003
3
How can I estimate the flowrate of assist gas (a gas with a higher heating value such as propane or natural gas required for complete combustion of a waste gas stream going to a flare? I have seen guidelines on assist steam for smokeless operation, but I have not run into guidelines for assist gas.
Any information would be greatly appreciated.
I worked on one flare that used assist gas (horizontal ground flare) that was essentially heavy NG, maybe 19 MW. The assist gas max design flow was 10 MMscfd, I believe the smokeless capacity of the tip was about 40 MMscfd from the vendor which would be about 0.25 lbs assist gas/lb flare gas.
This was off an oil processing plant. Flareman likely has the best information for you. What type of gas are you flaring?
It really depends on the reason for adding gas. In flares its normally supporting combustion of a low HV gas or providing assistance to achieve smokeless flaring. A good guide line is to use 300 Btu/Scf for combustion support for low HV gases to ensure stable combustion. For complete combustion try and aim for 600 Btu/scf but at the same time try and flare at a higher velocity, the closer to 0.5 Mach the better as the air ingress in to the flame at this exit velocity helps combustion also.
I seem to remember that API 521 does give some guidance on the issue although not alot.
Flaring diesel, you must be boiling off diesel at high temperature. Won't the diesel heating value be in the thousand of btu per scf. I am not a flare specialist but I believe you will need air to assist burning rather then natural gas and definitely not propane.
