gpape4
- Mar 8, 2012
- 4
Trying to qualify an existing vessel with no existing paperwork. Built 1939. Everything checks out except for inspection opening. Non-standard flange, flat plate, intergral/slip-on. The deficiency report keeps failing the gasket seating or fails at the g1 weld requirement. Used existing info gathered in the field and have latest thickness readings. It has held pressure for over 70 years, but the numbers say the flange is not good. Tried different gasket, larger bolts, different weld combinations; probably have done 20 iterations, still nothing works. Any ideas?
