magmath76
- Apr 27, 2011
- 20
Hi All,
If the tank bottom plate is 6mm and the annular bottom plate required also 6mm (as per table 5.1). In this case is it ok not to have the separate annular plate instead just extend the bottom plate to project 50mm outside the wall? which means wall just stit on the bottom plate.
much appreciated if some one clarify this.
Regards'
Magesh
Regards'
Magesh
