mcintya
- Apr 22, 2002
- 25
Does anyone know how to properly use this element?
According the the literature, it is supposed to help with modelling contact between shells and solids. Can you use this element replace the shell elements in a model so that you will no longer have a gap between adjoining parts, thus making the contact alot easier to set up? Can you use only one of these elements through the thickness of the part? If not, what would be the advantage of using this element over solid elements?
