IFRs
Petroleum
- Nov 22, 2002
- 4,675
I am looking at a wood structure made from 2x4 No2 grade Douglass Fir-Larch. There are 3/8" steel bolts 1 7/8" in from the ends of the 2x4's, the bolts are going through the 2x4's in the 4" direction ( 5" long bolts ). My question is: what is the allowable tensile load in the 2x4? I assume that the pull-out strength of the bolt in the wood is the limiting factor here. I need the allowable bearing load on the wood and any reduction needed for edge distance. What would be good sourced to find this info? Thanks !!!
