dik
- Apr 13, 2001
- 26,052
I'm not sure what I've done using Bricscad (Autocad work alike, and commands are very similar). I have a drawing border block that I've inserted into Paperspace. When I create a viewport using the borders and insert part of the model, the lines are slightly not parallel. Either paperspace block or the model is slightly off.
Any suggestions how to fix this so that horizontal lines are parallel?
When I check the block using a horizontal line, all is horizontal.
When I check the model, all is horizontal.
thanks, Dik
thanks, Dik
