mcfridge
Industrial
- Oct 21, 2004
- 26
Hello, I was just wondering if someone could help me set up the model for this? I have a frame with a distributed load across it. I'm just trying to simulate my case accurately, it doesn't have to be super technical or anything. I drew the frame in Solid Edge, saved it as a .stp file, and imported it. It meshed without any errors, and I've been able to run a few different simulations without problems. The frame is shown below.
As you can see, the I-beams in the middle (support) are facing the wrong way, and I want to see how much they are actually going to bend/flex in the middle and how it contributes to the overall deflection. I'm trying to figure out which surfaces I should fix or what I should do to set up my simulation (when I fixed the bottom surface of both of the bottom beams, it came out how it should look, but the bottom beams had no deflection). Also, the distributed load is only applied to the inside surface, but I had to apply it to the entire surface as shown below:
If this isn't clear I can try to explain it better. Thanks.
