air movement monitoring
mgw11
4
can anyone tell me the equipment best suited to monitor air movements, temperature and humidity levels within a room. I would like to set up a test rig on some sort of mast and conduct these tests over several days.
thanks
mgw11!
You can use room temperature sensors and humidity sensors for this application. How accurate you want these details depends upon the thickness of your pocket[wink]. Honeywell, Landes&Stefa and Sauters are some good manufacturers. Regarding air movement, if you just want to check from one room to another, use magnehelic gauges. They will only give you qualitative result. (i.e from where to where air is flowing)
Repetition is the foundation of technology
