Andy49
- Nov 23, 2011
- 28
If the yield test(y psi)of the induction bend is lower than the mother pipe(Y psi ), My understanding from ASME B16.49-2007 is that the paragraph 8.1 allows the following procedure.
1 Take the wall thickness of the pipe to which the bend connects (.x inch)
2 Divide the tested yield of the bend to the specified yield of the mother pipe (Y/y), which is a number greater than 1
3 Multiply the pipe (to which the bend connects) thickness (.x)with value obtained in 2
4. The bend thickness has to be equal or greater than the value obtained in 3.(Extrado thickness? even if not specifically stated in B16.49)
I just wanted to know if I was understanding the paragraph correctly. Thanks.
