rjw57
- Jan 27, 2002
- 109
I am currently working on a scheme to adiabatically cool a gas stream (high thermal conductivity gas (50% mol fraction) mixed with water vapor, nitrogen and CO2) from approx 350degC to 300degC using a stream of saturated water liquid/vapor injected into the gas stream at the face of an open cell nickel metal foam cylinder (gas stream flows along the axis of this cylinder). I cannot guarantee the mass quality of the water, just that it will be saturated. I am trying to make certain that the saturated liquid/vapor combo (~120degC) be injected at multiple locations on the face of a cylindrical metal foam (depth in direction of flow unknown), that it evaporate completely and obviously since the combined mass of the injected water and gas stream being cooled goes to 300degC, that the water becomes superheated. It is most important that the water is fully vaporized since any liquid downstream can affect the next unit op. The foam I am considering is ~ 90ppi open cell nickel made by INCO. Since this is only a concept at the moment, can anyone bounce any ideas on why this might/might not actually work. My two biggest concerns are: 1) distribution (ideally, the water vapor would be well mixed with the gas stream) and 2) total vaporization of flow for the smaller flow stream, the water used for cooling the gas stream. Flow is vertical down so that gravity is causing the water to flow in the direction of the gas stream.
To end, I should ask an even more important question - has anyone reading this done anything like this and would you be willing to share results?
Thanks,
Bob
Thanks,
Bob
