Jacst3
- May 3, 2010
- 22
Has anyone used the "Sd" factor when calculating the moment in a concrete tank wall? It seems that the "Sd" factor for flexural steel as defined in section 9.2.6 and 10.6.4 (ACI 350-06) lead to very high factored moment values. I am calculatng factors of 2.25, 1.9 and 1.7 which are used in addition to and based on the load combination factors defined in section 9.2.1.
ACI 350-01 only required the additional "Sd" fator of 1.3 for flexureal steel. Has anyone had any experience with this. Thanks for your insight !
Jason
Pittsburgh
Jason
Pittsburgh
