engjg
- Jan 2, 2015
- 96
Trying to decipher tie requirements for a gravity only column in a SDC D structure. It seems regardless of whether you evaluate the design displacement or not they send you to 18.7.6 which requires shear force calculated from Mpr? If so it seems the tie requirements are almost the same as it if it were a SMF column...? Also can anyone explain to me in layman's terms what ACI 318-14 18.6.5.2(a) means?
