SJEC
Petroleum
- Jun 21, 2004
- 41
I am working on a new vessel with 30" dia and 1380 psi @ 180F. The above pressure actually choosed by B16.5 pressure-temperature rating.
I am try to use standard B16.47 on girth flange and receive a warning say the MAWP of 600# flange is 1376 psi.
However, 24" B16.5 flange MAWP will be 1384 psi from Compress.
I have checked B 16.5 and B16.47 pressure-temperature table. They are identical. Therefore, It muse be compress is using different interpolation method between B16.5 and B16.47.
Tom, Could you check it for me? Thanks
