820nm device on 850nm switch ????
sparky1976
87
I got several 820nm multimode device 10Mps(a remote electrical meter)I'm thinking of buying a switch for that substation, can I use 850nm switch 10Mps, because I cannot find any swicth that specified 850nm ?
thanks
Pitat Haeng
Chances are that the receiver on the 850nm switch will accept an 820nm signal. To be certain, you should look at the spectral width of the transmitter and the range of frequencies the receiver will accept. As long as you aren't pushing the attenuation limitations of the fiber, I don't think there will be an issue.
