DaSalo
- Apr 27, 2010
- 213
I am trying to generate a toolpath to cut a relief slot at the base of a wall. The wall has a wavy contour and the floor also has a wavy contour in the z axis. The slot is a .0625 radius in cross section so I'll need to run a 1/8 ball mill right down the center of it.
I'm fairly new to to NX and haven't done a lot of contouring yet so am not familier with the tools outside of Cavity Mill and Fixed Contour. I see a tool called 3D profile. Is this the tool for the job? Will it be necessary to elminate the fillets in the model so the the system will only see the Z depth at the bottom of the slot? Thanks if advance for any help.
-Jeff
-Jeff
