3D Printing note
a0r0t
28
Is there a standard note used on drawings for 3D Printed parts?
Thank you.
-Art
a0r0t,
Is anybody going to read your drawing? My experience has been that 3D[ ]printers do not. What does your 3D[ ]printer need to know?
Don't stick notes on your drawings (or work orders) just for the heck of it.
JHG
This is what we're using. And yes, the drawing is read.
1. FEATURES, CONTOUR AND HOLE LOCATIONS ARE CONTROLLED
BY THE 3D CAD FILE.
ALL NON-DIMENSIONED FEATURES IN THE CAD FILE ARE TO BE
CONTROLLED BY THE DRAWING TOLERANCE BLOCK. NON-
ANALYTICAL SURFACES ARE DEFINED BY THE 3D CAD FILE
TO BE PRINTED USING STRATASYS DIMENSION SST 1200es
PRINTER OR EQUIVALENT USING THE FOLLOWING SETTINGS:
MATERIAL: ABS PLUS
MODEL INTERIOR: SOLID
COLOR: ANY
MODEL FILE: T850123-01-10A.STL
I'd called out "FDM PRINTED" instead of an actual 3D printer brand, and maybe add your requirements for layer thickness. If you don't want your parts bonded together, add "NO SEAMS" or similar wording.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read faq731-376 to make the best use of these Forums?
Pointless if your tolerances are out of whack. Especially true if all you have is +/- tolerances in the block. You ought to have a blanket default surface profile with defined datums.
In which case, the solution is to get your tolerances back into whack.
No need to make things any more complicated than they have to be.
