14159
- May 31, 2005
- 175
The 1989 and 1999 Specs both have an entry in Table B5.1 called “Webs in combined flexural and axial compression.” I don’t see any entry in the 2005 equivalent table to cover beam-column webs. I think that a dogmatic reading of the table would lead one to use Case 9 or 11 for any I-shaped beam-column and Case 10 only for a gravity column with no calculated stress gradient across the web. Does anybody have an opinion or other knowledge that helps with this issue?
Thanks in advance.
DBD
Thanks in advance.
DBD
