ElCap
- May 15, 2006
- 15
Hey guys,
im designing and creating a rfid system as a project with a few friends.
i have the task of designing the reader antenna.
the antenna part of this proj is being discussed further but the point of this post is to get some info on directional couplers.
ive been informed that we will need a 180 degree directional coupler between the reader and the antenna.
ive included a link to a pic of what im talking about to help you guys understand what im trying to say.
As i understand it, the antenna is transmitting and receiving the signals at the same time. and the received signal is going to be relatively weak compared to the transmitted signal, so its hard to seperate the signals
the info that i have been reading bout the 180 degree coupler seems to say that it will split up the incoming signal into two signals or combine two signals into 1.
What i need (as shown in pic) is be able to direct the transmitting signal to the antenna and direct the received signal to the receiver module.
Am i right in choosing a 180 degree coupler?
if yes could some explain it some more as i dont understand it fully?
Thanx
Rob
Thanx
Rob
