17-4PH cold rolling
gpss
Materials
Sep 25, 2005
3
Can anyone tell me what's the exact process to cold roll 17-4PH from say 4mm thickness sheet to 0.4mm ? That's a 90% reduction...considering at 4mm we start with 17-4PH "A" conditions, how many times the alloy needs to be heat treated, annealed, re-heat treated, re-annealed etc. ? What's the amount of cold reduction possible in a single pass ?
Ajit Pai
I am not sure about sheet, but I have seen wire drawn in the overaged condition. It has better ductility overaged than annealed, and it strain hardens less.
Plymouth Tube
Thanks ED. Overaged is Double heat treated at 1150 right ? What's the maximum reduction possible in this condition ? am I right to assume approx. 20% ? Further re-anneal, re-overage and cold draw again ? Repeat the process till you achieve the desired reduction ?
Ajit
At times when we had do severe coining on 17/4 parts we would go to the H1150-M heat treatment.
2 hrs at 1400F
air cool
4 hrs at 1150F
air cool
We have heat treated the same part with this procedure several times.
Ajit
I don't know the strain hardening coef, but since other grades are often reduced 40-60% I would think that you could get close to that with this alloy.
In wire work they don't reanneal, they just re-over age. That works as a stress relief.
Plymouth Tube
