Sa-Ro
- Jul 15, 2019
- 279
Refer figure 7.7 datum plane establishment from ASME Y14.5:2018
Doubt 1:
Should I take measurements (dial/probe zero setting) from datum plane A (true geometry counter part of datum feature A) or Simulated datum plane A (plane derived from datum feature simulator such as surface table, chuck, vice, angle plate etc).
Because, the datum surface of the part may have imperfections which will effect in our measurement result. Surface of the datum feature simulator shall have less imperfection than part.
Doubt 2:
If we declare a surface as a datum, the entire surface must be located with datum feature simulator. Then how to touch and dial zero setting at part surface?
Doubt 3:
If we declare a outer dia as datum (Ex: Dia 50 X 100). Should I locate the entire length 100 to achieve the datum axis?
Thank you.
Doubt 1:
Doubt 2:
Doubt 3:
Thank you.
