XFOIL
vktsn0303
New member
Sep 10, 2013
23
How to export the XFOIL output (Cp VS chord plots) to a PDF file?
vktsn0303
It looks like XFOIL only supports Postscript output. This can be converted to PDF with Adobe Acrobat or GSVIEW or other similar programs.
I don't know if there is a command you can use to export the plot. Maybe. But anytime I've wanted a picture of the cp graph I've just used the snipping tool or something else that can make a jpeg. Then you can drop it into a word processor and print / export as pdf. Seems just as simple as exporting from the program, if that is even possible.
Keep em' Flying
//Fight Corrosion!
