JeremyLee17
Geotechnical
- Aug 27, 2020
- 1
This residential site has expansive clay. It appears that the building pad is poorly compacted, dry, in-situ clay scrapped from the surface of the surrounding area. The building pad levels a slope with a max depth of 5 feet.
I provided the geotechnical report and I am to design the foundation. I specify in the report, by email, and on the phone the risk involved with building a slab-on-grade under these conditions.
The contractor communicated by phone call that he will use water injection on the building pad.
It seems to me this contractor has only one plan in mind: To push dirt in a pile and build a slab-on-grade. I don't think he intends to use water injection and he will not specify his intentions over email. I feel there is a good chance I will not get compensated for any performed work.
My questions are:
1. If the pad is water injected AND I take samples for a swell/settlement under expected loading AND neither swell or settlement is significant, could there still be significant long term 'secondary settlement'?
2. If I design the foundation I don't think it is my uncompensated job to catch them building it improperly, but at the same time I don't want to design something when there is this much obvious risk. If I make it clear the risk involved with the contractor's plan and go forth to design the foundation, would I be acquiring unreasonable liability?
My questions are:
