VS4 pump
adula29
53
I asked this question on the API 610 forum but got no answer so I'll give it a try here.
I have a question about the type of bushing material that should be used in VS pumps, e.g. VS4.
API 610 recommends the material filled carbon for bowl shaft bushings. What about pumping gasoline, i.e. flammable liquid. What about wetting the bushings, is it enough to wet the pumped liquid and avoid the risk of explosion.
Does the API 610 standard allow the use of bushing materials other than filled carbon?
