jmbelectrical
- Jul 16, 2011
- 126
A 240/120V, three-phase, four-wire, delta high-leg system comprised of three (closed delta) pole-mounted transformers serves two commercial properties. One of the transformers presumably failed, resulting in the opening of its primary-side fuse cutout. Both properties allegedly suffered from damages that are consistent with an overvoltage event.
By what means could the failure of a transformer result in overvoltage on its secondary side?
