drewnje
- Nov 18, 2010
- 28
A client is running a new 4" water service line onto their property. The pipe is going to be ductile iron and terminate at a 4" gate valve in a concrete valve box to which they will attach a hose to be utilized as needed for filling water trucks and such. The water line will supply approximately 225 gpm at 50 psi. Are thrust blocks needed at the terminal end of this water line? If so any advice on how best size and construct thrust restraint in this kind of application would be much appreciated.
Thanks!
Thanks!
