Thin wall - Diecasting
Vikas4auto2019
13
Hello Guys;
I have made the following model..to be die-cast with ZP5.
box dimension is 15x22x12mm...is 1.5mm wall is enough here? .although that area is not taking any load.
Thanx in advance!!
Vikas4auto2019,
What do your vendors think?
JHG
@drawoh
I have not approached any vendor so far. Design is still in the initial stage.
I just need a basic idea about the thin wall in the above case.
What does that bottom surface look like - is it a gradual taper from the thicker looking wall in the left view to the thin wall in the right view? Or is there a sharp step somewhere? In general, a gradual taper might still be castable.
Vikas4auto2019,
This is the time to approach a local vendor. If they say they can do a 1.5mm[ ]wall, you can call one up. Probably, they have a design guide for you.
JHG
@Btrueblood
Yess there is a sharp step down...which is must for its functionality.
If it is so thin then it can likely be eliminated and just run the slot all the way through.
Check the net, quick looks tells me you can cast to Min. 0.4mm
