GaStruct
- May 20, 2024
- 74
I have a residential project where the contractor and steel fabricator ignored my details requiring a column cap plate bolted to the bottom flange of the beam - the standard detail you always see. Instead, they field welded the column directly to the beam's bottom flange.
So, I have two questions:
1. Assuming the field welds are good, what issues do you see with this connection?
2. Assuming the field welds are no good, what repair options do you see? Just re-welding it is not ideal with all the adjacent wood framing already installed.
Photo is attached.
Photo is attached.
