Star delta
Apr 16, 2025
1
Hello everyone
I'm New in the form yesterday I found electric panel is looking strenge. inside panel vsd and Star Delta control circuit for water pump motor
Why we use both together
Why we use both?
I think one method is enough
Star connection is better for low loads. If your pump is below 5KW, then you have lower current in each line, and low starting torque required.
A star connection will draw less current at start than a delta connection, and because this is a solar panel, your power is limited, so go star connection.
Starting current is somewhat moot with a VFD.
I suspect that a VFD was installed and that the original star-delta starter was abandoned in place.
On the other hand, there may be some merit to Ethnan's suggestion.
Do you know something that we don't know?
VSD (Variable Speed Drive) and Star-Delta are typically used as redundant systems, commonly found in data centers and other critical applications. If a VSD fails, the replacement process can be time-consuming. In such cases, other conventional starters are used to reduce downtime and minimize production losses.
