Spirals 2
spee
19
I was looking to make a simple 2D spiral. I needed it to be about 6 loops. I made one using points and the spline command. The spiral did not come out perfect, seemed a little uneven. Is there a command to make a perfect spiral.
Mike
i have a spiral lisp u can load in your drawing so u can draw even 3d spirals if u like, i may b able to send it to by e-mail, so i will only need to know whats your e-mail :)
Pea$e
You can get a 3D spring(sprial) by following the following steps:
1. Draw a donut.
2. Slice the donut along a diameter, keep both halves.
3. Rotate the two halves in opposite directions for an equal angle, let's say 10 degrees.
4. Array the result.
Good luck!
