Smaller Metric Size GLT formulation O-rings
jimbod20
Aerospace
Sep 8, 2010
75
I need two specific o-rings that I cannot readily find. Are there any recommendations on where I can find and buy these o-rings? Both are a metric size in the Viton GLT rubber formulation.
#1 size 1.5mmx6mm
#2 size 1.5mmx8mm
If it's a small order, McMaster-Carr is pretty good about sourcing odd parts off catalog. You may have to explain that you need a specific formulation of Viton. They should also be able to provide material certs.
